I want to swap the drops on my Jamis Aurora 2015 to trekking bars.My spec is here https://www.evanscycles.com/jamis-aurora-2015-touring-bike-EV210733
Front Derailleur
Sora FD-3503 front with 28.6mm alloy clamp
Rear Derailleur
Shimano Tiagra RD-4600GS rear
Number of Gears
27
Chain set
FSA Alpha Drive triple, 165mm (47) 170mm (50/53/55) 175mm (57/59/62)
Chain rings
48/36/26T
Cassette
11-32
Chain
SRAM PC951
Brakeset
Tektro 992 forged alloy cantilevers
Brake Levers
Tektro RL340 road brake lever
Handlebars
Jamis Ergo, 6061 aluminum, 31.8 x 380mm (47), 400mm (50/53), 420mm (55), 440mm (57/59/62)
Stem
Jamis adjustable threadless system (ATS) forged aluminum stem, 10�?� x 90mm (47/50), 105mm (53/55), 115mm (57/59/62). ATS shim length 100mm
Shifters
microSHIFT bar end shifters with index or friction option, 27-Speed
The only deviation from the original spec is the cassette. I bought an 11-32 and the trekking bars of course.
I think I will have to change the full brake system so I am planning on buying some Shimano Deore brakes.
What I am not sure about are the shifters. I want the thumb shifters but I am not sure of the compatibility with my FD and RD. Ideally it would be better/cheaper if I did not need to change them and I just needed to buy shifters.
Front Derailleur
Rear Derailleur
Number of Gears
27
Chain set
Chain rings
48/36/26T
Cassette
11-32
Chain
SRAM PC951
Brakeset
Brake Levers
Handlebars
Stem
Shifters
