Eccentric Bottom Bracket
Cycling Badger
Why do the small jobs end-up growing arms and legs!
Two simple jobs to do, thought I could squeeze them in an hour on the tools.
1) Reduce length of gear-cable runs to Rohloff after switching from 90mm to 50mm stem
2) Check stretch and re-tension the chain at EBB
Turns out reducing cable run on Rohloff takes a little bit more attention and research than Derailleur based bikes. Good information on-line and was all going to plan until I realised the pin on the transfer box that secures cable box had unscrewed. PITA to get to the back of the bolt. Requires wheel out and removing the brake-disc and fiddling with a small hex-key between transfer box, spokes and hub-shell. And since you have the disc off, and probably transferred some grease on it you better give it a clean. Cable now shortened and big loop of cable that was annoying has now been shortened - maybe a fraction too much :-(. On the plus side, I’ve not replaced cables on Rohloff before and I now have first hand experience.
Loosening and rotating the ECB is one of those job I do at most twice a year. Always have to try and remember the brand and check instructions on-line. Anyway after much swearing and trying not to be too ham fisted with hex wrench I decided that it may be stuck in BB shell. Liberal application of WD40, removing the cranks and bottom bracket (which hadn’t be done in 5-years since bike was first built) and a little persuasion with the rubber mallet and it came free. But felt pretty gritty when turning. Given this a judicious use of WD40 decided it was time to remove, clean, grease and reassemble the EBB. Reassembled, tensioned, cleaned and lubed chain. All good, and if I’m honest, a satisfying job.
Trip to supermarket abandoned and left-overs for dinner as bike took priority.
I thought some on the forum would empathise with the “jobs growing arms and legs” and other may be interested in what a stripped EBB looks like.
wakemalcolm
Ratho
I feel your pain. The EBB on my Thorn seized and the part of the frame housing the giant grub screws snapped off due to corrosion leaving it stuck in the shortest chain length. It survived to the end of its life by regularly replacing the chain.
Paulus
Barnet,
Good morning all from Bayonne.
Today we are going to explore the old town which is over the other side of the river Adour.
The EBB on my old Dahon Cadenza was a solid chunk of Al held by a split BB shell clamped with 2 bolts.
The EBB could rotate within the frame shell but I never tried remiving the cartridge BB from the EBB lump. Not sure how that would be done.
