A bit off topic but i have an electrician friend who'll sort your meter for 50 quid. If interested PM me,but keep it quiet!![]()
I build my own DAC's and headphone amps having started with absolutely no electrical knowledge.
The best resource is http://www.diyaudio.com/ although some of the threads are older and bigger than CycleChat and you need some experience to interact on there.
I started learning about simple circuits and then about power supplies (which are the biggest worry when starting) then got me a good soldering iron and practised soldering and de-soldering.
Finally I had a think about what to build ( a DAC in my case) and then ordered a £15 kit from China off ebay which is in my opinion the best way to start - you just solder everything to the board, connect some power and hope that you are hearing something.
How about a Raspberry Pi? Many kits of varying complexity and price for them, and a huge network of boffin users to advise you.
Did it work?
I need a new hobby. Rather than wasting time on here I need to waste time on something else.
Electronics appeals because it's more or less a mystery to me. I mean I can cobble together bird tables from wood, strip engines (once, couldn't be arsed now) do a few other things but have absolutely no idea about electrical/electronic things and how to wield a multimeter.
I don't know where to start though. With a book, with a kit, build something, what? I'd like to build a stereo amp but I suspect I'll need to work up to that. I'm not so interested in things like the Raspberry pi, at least not yet, Id rather begin with understanding circuit diagrams and soldering components and stuff.
So where exactly should I start?
Also someone needs to challenge slomos bid for world domination.
You sound like the guy in the Hovis advert.Model Railways... proper multi-skilled hobby
Amazingly yes - for about 10 minutes until something overheated because I had wired it the wrong way around![]()
Tied in with electronics. Automatic signals, working SPAD's, level crossings.Model Railways... proper multi-skilled hobby
