Had a doubt about how I ran the cables 🤔
Some how it seems wrong ie the cables should be in front of the bars ?
The length of the loop from the brake lever over the bars is personal, I tend to go for a short cable run
Has polished up very nicely. Kudos.
I'd second the implied recommendation to make both cable runs shorter and lower. I'd be irritated by cables that close to the centre of my field of vision when in the drops.
I’d forgotten just how precarious it is descending on rim brakes that sometimes decide not to work
You've got the brake levers mounted too high on the handlebars, with those older brakes you need a full grip on the levers they're not 1 or 2 finger jobbies like modern brakes.
Geometrically, I cant see why moving the brakes further down the curve of the handlebar will bring the lever closer.
I recommend looking at where brakes are positioned in last century photos many. I'd say they were about right: any lower then riding on the hoods would become less comfortable. YMMV
Good effort climbing those with a 40" gear.
André Foucher, who died earlier this month at the age of 91, won the Midi Libre stage race twice (1964 and 1965), and was sixth in the 1964 Tour de France.
