mojones
- Midlothian
This is quite a rare bit of kit! The White Industries ENO eccentric hub is a rear hub with an offset axle which is designed to let you adjust chain tension. Read about it here:
http://www.whiteind.com/rearhubs/singlespeedhubs.html
The result is a hub that lets you convert any bike with vertical dropouts to fixed gear. The hub is built up with a Mavic OpenPro rim and has a fixed gear on one side and a freewheel on the other. The fixed gear side has a White Industries 16 tooth cog, and the freewheel side has a White Industries 18 tooth freewheel.
I used this wheel to convert my Spec Sirrus Sport into a fixed gear bike (and it was insanely fun to ride) but I recently moved house and had to convert it back to stock in order to use it for commuting - sadly my knees refused to function when I asked them to push a fixed gear for 25 miles every day! The wheel is in excellent condition, and has only done about 200 miles from new. Total cost of components was around £250 as listed below; I'm asking for £150 including postage by Royal Mail special delivery. Pics below.
White Industries ENO eccentric hub - £120
700c Mavic OpenPro rim - £30
White Industries 16T cog - £35
White Industries 16T freewheel - £75
Any questions just ask.
Cheers,
Martin
Cheers,
Martin
