Black Sheep
- Rammy
I've got damp markings on the celling of my front bedroom
The house is a mid terrace (apparently used to be an end once upon a time) built around 1912-1915
The celling is plasterboard screwed through the cracked artex ceiling with a skim added.
This mark is in the shape of an F with the light fitting being on the lower horizontal mark, presumably at the joins in the plasterboard.
From outside the tiles appear to be ok, can't see any out of place. I've had a roofer look, he says the roof has dipped slightly in comparison to our neighbours or there could be a cracked tile somewhere that we can't see without stripping the slates off - his solution, to guarantee resolving the issue, is to strip, underfelt and re-slate. I can see his reasoning.
We're wanting to look into having a loft conversion / hobby room later this year so doing this now isn't really fitting with logic to re-roof, to end up re-roofing but I don't like the fact the light buzzes and crackles from time to time if it's rained recently.
As far as I'm aware it's not actually dripped.
I have had a look up in the loft and can't see any chinks of light coming through, had a glance today while it was raining with a torch but couldn't see any signs - bit worried about climbing in properly as I know the joists are only thick enough to hang the ceiling not take my weight.
Basically I want to divert this water from the electrics to somewhere it can sit and dry out as it appears to be a couple of drops finding their way through.
