sleaver
Ive been looking to get a bike recently because although a run 30-40k per week, I'd like to give my joints a rest from constant pounding while still keeping fit.
I'll apologise for the length of the post now, but I've been out to Evans Cycles and Halfords this morning and now have a few bikes in mind but would appreciate some other opinions.
Firstly, with Evans, I wasn't expecting to be able to ride them but they let me ride down the road and back. After not having ridden a bike for 15-20 years that was quite interesting. It was a case of how stupid could I look weaving all the way down the car park
Hybrid wise, Evans suggested the Specialized Sirrus Sport 2012 Hybrid Bike | Evans Cycles and said it was a good make because make most of their spare parts as well.
Halfords suggested the Halfords | Boardman Performance Hybrid Comp Bike 2011/2012 - Large 21" because it probably meets my needs and the Halfords | Boardman Performance Hybrid Team Bike 2011/2012 - Large 21" doesn't really add that much for the price. They also suggested the Halfords | Carrera Gryphon Hybrid Bike 2011/2012 - Large 21"
Road bike wise, Evans, although they didn't have it out, suggested the Specialized Allez Compact 2013 Road Bike | Evans Cycles as it's within my budget and is a 2013 model. Halfords suggested the Halfords | Boardman Road Team Bike 2011/2012 - Large 55cm because they advised against the Halfords | Boardman Road Race Bike 2011/2012 - Large 55cm for reasons I'll come to in a moment.
Evans Cycles were explaining that on road bikes, they gear selectors can be in different places. The bikes in my budget had the brakes as one selector but the other was in a position that you couldn't reach if you had your hands on the drop bars. Where as, on the more expensive bikes, both were on the brake levers and could both be reached on the drop bars. So, although my budget kind of decides what I go for, is having one of the selectors out of reach when on the drop bars going to be a problem?
Now, Halfords suggested the more expensive road bike because of the bottom bracket being a BB30 one and that there would be no point in going for the Comp because in 6-9 months time, everything will have a BB30 bottom bracket and it's apparently so much better. Is that true or should I be looking at the Team instead of the Comp?
Halfords also said, because of the roads, I should probably go for a Hybrid as they may be tough going for a road bike and wear it out. Probably the best way of describing the non A roads around me is that there pretty much normal B roads compared to the standards in this country. Uneven and quite a few pot holes. The following is the worst that I could think of and even then I probably wouldn't use it as It'd stick to a wider road parallel to it: Smallfield - Google Maps. This is close to where I live: Smallfield - Google Maps
Lastly, after riding a hybrid and road bike, the road bike felt more comfortable because with the hybrid, I seemed to be supporting my whole body weight with my arms dead straight, where as with the road bike, they were more bent and relaxed. My back did ache a bit but then it does when I've been standing still for quite a while and I assume it's not used to riding which if the later is the case, I assume it would get used to it and adapt after a while.
So if that lot hasn't sent you to sleep, what are your opinions? I think the main things I'm thinking about are:
P.S. Evans Cycles said that a 58 sized bike is probably right for me however, Boardmans only seem to go to 21"/55cm. Would that be a problem?
Oh, and I can safely say, riding a £1200 road bike is quite nerve racking considering I have never ridden a proper road bike in my life!
- Road or Hybrid. I think I would prefer road but will some roads around me allow it! Although I have seen road bikes around here as well as hybrids.
- Gear selector positions although my budget will probably be the deciding factor on that!
- Opinions on the bikes that have been suggested to me.
- Are Halfords right about the BB30 bracket?
and went to a different
