SirDickieBird
First off, thanks for everyone who reassured me in the other thread about my new purchase of a Carrera Virtuoso.
Went for a proper ride yesterday - I usually do 25-30 miles on a weekend morning. Yesterday found myself doing 47 miles and thinking "this is the best thing I've ever bought"...
A few things to note that I wonder if you can help with / offer advice / experience on:
Pro - much quicker on the flats and gentle gradients
Con - The strava times I've been steadily improving to monitor fitness have been blown out of the park! Took 20 seconds off a 4-minute sprint section and clocked around 20 PRs without full beans. Got to start all over again now and also lost the sense of pride I had being in the top few (or not bottom) on a MTB
Pro - saddle (despite being narrower) more comfortable. Also no back ache which i got on the MTB which is strange as thought it might get worse.
Con - Road vibrations when rough! Bone-shaking...
Pro - Aerodynamic down-hills
Con - scary! But the brakes are good.
Pro - Slick gear changes and smaller steps between gears so can change up when gradients level out and make more progress
Con - Can't get biggest cog on the back...
which leads to the biggest issue...
steep hills
Despite restricting myself to using middle ring on the MTB and not the granny ring, I could (just) get up the steep ones around me - http://veloviewer.com/segment/675462/Terrington+Bank
It wasn't pretty but I could just do it.
Yesterday - had to get off and push...although I was trying it after already doing 25 miles whereas it's usually closer to my start.
It's my legs that give up - don't have enough push up the steep bit.
Am I right in thinking (after research) that I might be able to get the biggest back ring by adjusting the low limit screw? I'm hoping that the extra ring might be enough to get me up...that and extra training...
Going back to strava - I'm getting in top half at least for most flat-ish sections but languish near the bottom on steep hills.
I've read through the other thread about getting up hills and don't really want to start messing with new cassettes (if I did, would I lose out at the top end?)
steep hills
