Fixed cup width
lenfield
Does anybody know the distance between the flats on a traditional fixed cup?
I've got one that keeps loosening itself. I know you can buy specific spanners but I'd rather by an adjustable one so it can be used on other things.
Paulus
Barnet,
Normally a fixed cup is 35mm between the flats.
If you were to buy a fixed cup spanner they Normally double up as pedal or headset spanners for both.
C R
Worcester
I'm surprised it loosens itself. The design makes them sort of self tightening, and they are notoriously difficult to remove because of how tight they become.
An adjustable spanner doesn't work very well because the flange is thin and the adjustable doesn't get much purchase. Attempting to use an adjustable may result in damaged knuckles and loud swearing, DAMHIKT.
I'd also second getting the right tool for the job. Especially if you want to preserve the paint on your vintage bike ! The tools aren't expensive, and you may get a 15mm pedal spanner on the other end - bonus very handy tool. Assuming this is a fixed cup BB.
Paulus
Barnet,
Old style fixed cups have the opposite thread on the fixed/drive side so undo clockwise. They must be done up very tight to stop them coming undone.
midlife
They have a left hand thread because precession tightens them up in use. Same with pedals, in theory. Have you an LBS who can use the proper tool, probably cheaper than buying something.
  • Like
Reactions: C R
C R
Worcester
My understanding is that the drive side thread is always a reverse thread because the bearing precession will tend to tighten them. There are old French and Italian standards that use normal threads in the drive side, so undo counterclockwise, those will tend to undo themselves unless done up very, very, very tight.
All this is according to Sheldon, who also recommends against trying to use an adjustable spanner.
