bleakanddivine
- Way on down south, London Town.
I know I should have waited until Christmas, but I have just bought a new toy - a FlyCamOne2, and I've just had a chance to play around with it a bit. I bought the Extreme Battery Pack with it, and a couple of Sandisk Ultra 2GB SD cards. The cards haven't arrived yet but luckily I already had a Sandisk Extreme 1GB SD card which will do for now.
First impressions - kit is beautifully presented and packaged in custom fitted MDF boxes. Manual is barely OK, with plenty of that awful literal translation gibberish which looks as if it's been fed through a tranlation program. But you can make out the gist of it.
Everything works like it says on the tin, the only problem I had is not being able to update the firmware. The instructions that come with the downloaded update file are not great and even following the link from Magnatom's article to alternative instructions I wasn't successful - only getting a message 'Unable to initialise device. Check drivers and hardware' when running the update program with the FlyCamOne connected by USB.
The Battery pack sits on the cam like this.
Mounting to the bike. I'd decided that I wanted to use the FlyCamOne as a rear-facing cam, and that I would try and attach it under the saddle somehow. I figured it would probably be safe from rain under there, and there was enough room above my Altura seat-post bag for some sort of rig-up involving velcro cable ties. I wasn't sure exactly how this would work until it arrived and I had a chance to experiment a bit.
The thing was a lot smaller than I had imagined, but I managed to create a sort of velcro cradle for it that attached itself to the velcro at the top of the Altura straps that hung from the saddle bars. Another strip of (red)velcro round the bars and cam itself and it was pretty secure. It slides rearwards out of the cradle so that the on/off switches on the side can be accessed, then it is pulled back into the cradle by its lanyard, which is then secured by velcro round the seat post. Sounds pretty botchy, but it is actually pretty solid, and it can also be removed or mounted quite quickly by releasing the seat-post velcro and sliding it out rearwards. Here's a couple of photos of the mounting.
The only problem is that it can get a bit wonky when putting it in, so verticals are not necessarily true on the resulting pictures, but it's liveable with. I took it for a quick spin round the block and the results are here.
http://www.stealingdan.co.uk/bikecam/bikecam1.wmv (big file)
This is a file that I imported into WMV, clipped the ends of, had to rotate 180 degrees, and saved at 2.1Mbps. It's about 37Mb. The original was about 153Mb but upside down, so very hard to watch. I can put the smaller file up on Youtube if anyone wants, but the quality will be worse.
Not too bad, bumps in the road not withstanding, and you can read the nearside car plates if you pause the clip. No idea yet on battery life, SD card capacity etc. All in all pretty good for about £90 all in.
Jonathan
Jonathan
