For when the AirZound just doesn't cut it
thomas
the tank engine
Woking/Norwich
Think I posted that ages ago...just as part of a thread mind :mrpig:
Femto
Femto
Nuts. I searched and everything. Probably a bit of a needle-in-a-haystack type futile search but yes, that was a fail.
Still, I found it amusing enough to post. :mrpig:
thomas
the tank engine
Woking/Norwich
Still, I found it amusing enough to post. :biggrin:
Haha. Air zound is usually pretty effective - it seems a few people have bought them from seeing them in action on my youtube videos (I recon I need to start making a commision on them :mrpig:). Wouldn't mind a ride around with that though...down the local tow path :biggrin:....or outside the police station then play all innocent.
Femto
Femto
Well it'd have to be somewhere flat....or downhill. I think your legs would probably explode if you tried to climb a hill whilst carrying that air tank. ;)
Going out to work tomorrow for the first run equipped with the airzound. Must....resist....un-necessary....tooooting.
Seriously though, I'll be adult about it.
I have two of these fitted to my bike.Apparently I made a few peds jump the other day when I applied my finger to the button.This is what my work colleague cyclist told me anyway.
thomas
the tank engine
Woking/Norwich
Have fun!! I still do the occasional, "hey, you honked me for no reason...I can do that back" - beeeeeeeeep....then someone cuts me up and I'm out of air and something that sounds like a wet fart comes out.
So, Top Tip: Don't abuse it, but do give little warnings to people when appropriate.
I think I used mine a bit too much on close overtakes this morning so will have to pump it up before leaving.
How have you got that set up 666? They look similar to the ones on my motorbike but that's hooked up to the battery.
