Marie Attoinette Fan
I am currently using avast anti virus (freeware) and it seems to work ok, is there a similar freeware firewall product?
Thanks,
Thanks,
I'm on Windows XP, with Firefoxsatans budgie said:Ok no firewall on the router.
If you are using M$ Windows can I suggest that you switch on the M$ firewall and do a port probe. This is a test to show which ports are open and will provide a benchmark to test a new firewall installation against.
Go to this web page and select the common ports option.
For reference copy and paste the results into a word type document.
If you get a pass result then you are pretty well secure.
If the result cause some concern download the free version of Outpost. Install it and repeat the test. Compare results if no better, let me know, uninstall Outpost and I will get one of my network engineers to do some research.
HLaB said:I'm on Windows XP, with Firefox
All I'm getting on that web page is Shields Up!! - System Error, Browser Reload Suppressed![]()
I still have IE but I think I found the tool page and ran a test it looks OK to me but I'm no expert.satans budgie said:Do you have IE still installed give the cut and paste the link in to the IE address bar. http://www.grc.com/x/ne.dll?rh1dkyd2
The free version of zone alarm is IMO designed to scare the unwary into purchasing the product. Not very subtle marketing ploy, but a competent product nevertheless.
HLaB said:Found it SB, I'm getting, I trust that's OK:
[SIZE=-1]----------------------------------------------------------------------
[SIZE=-1]GRC Port Authority Report created on UTC: 2009-09-29 at 19:46:43[/SIZE]
[SIZE=-1]Results from scan of ports: 0, 21-23, 25, 79, 80, 110, 113, [/SIZE]
[SIZE=-1]119, 135, 139, 143, 389, 443, 445, [/SIZE]
[SIZE=-1]1002, 1024-1030, 1720, 5000[/SIZE]
[SIZE=-1]0 Ports Open[/SIZE]
[SIZE=-1]23 Ports Closed[/SIZE]
[SIZE=-1]3 Ports Stealth[/SIZE]
[SIZE=-1]---------------------[/SIZE]
[SIZE=-1]26 Ports Tested[/SIZE]
[SIZE=-1]NO PORTS were found to be OPEN.[/SIZE]
[SIZE=-1]Ports found to be STEALTH were: 135, 139, 445[/SIZE]
[SIZE=-1]Other than what is listed above, all ports are CLOSED.[/SIZE]
[SIZE=-1]TruStealth: FAILED - NOT all tested ports were STEALTH,[/SIZE]
[SIZE=-1]- NO unsolicited packets were received,[/SIZE]
[SIZE=-1]- A PING REPLY (ICMP Echo) WAS RECEIVED.[/SIZE]
[SIZE=-1]----------------------------------------------------------------------[/SIZE][/SIZE]
