Armegatron
Cleaned the cassette with gt85 on the bike, being careful not to let any get into the freehub as I always do. Then went for a 50 mile ride. 49.9 miles in and I noticed a noise similar to when the magnet on the spokes hits the pickup on the chainstay. Turned out this was the freehub making the noise.
The noise is only when freewheeling or slightly worse when backpedaling and sounds like it could be an ungreased pawl. The noise only happens when freewheeling when the pedals are at a particular o'clock position (ie when the freewheel is in a particular position). Any other position and it is silent.
The freewheel engages properly when pedalling and is quiet under load. When the bike is upside down and the wheel is spun so the pedals should not rotate, the pedals are not being forced to turn by the freewheel, so again smooth yet noisy when the pedals are at a particular position.
The final point, there is a slight oscilation (wobble) when the freewheel is spinning freely regardless of pedal position, suggesting the freewheel could be loose.
There is some urgency to get this sorted as I am doing a charity coast to coast ride on Friday and I'm wondering...
1. Do you think I will be ok to ride the 150 miles on the C2C and get it repaired after?
2. Would a liberal application of more GT85 and application / soaking of chainoil possibly be a fix?
3. Does anyone living in the Teesside area have an 11mm allen key that I could borrow to remove / retighten and regrease everything?
4. How much would you expect a whole new rear wheel with a branded hub and freewheel to cost (as I may just go for the quick fix route at the LBS)?
Bike is a 2011 Tricross Sport
Hub is unbranded OEM, presumably the freehub is too.
Bike has done 1020 miles
