scotsbikester
Is it? Maybe once a week?
Yup, why ?
Maybe or maybe not but the burning question is why would you? Usually you fit and forget or at least until things wear out.
This isn't "usually" then.
What way may it be harmful?
Is it [harmful]? Maybe once a week?
You could also damage the threads on the frame by repeated loosening and tightening the cups.
Back in the day when these were the norm it would be a once a year job unless you had a problem.
Repeated fitting could damage and enlarge the taper on the cranks. They aren't designed for weekly removal. Why would you do it. You could also damage the thread for the crank removal tool - easy to do. More you do it, the more potential for an error.
But why would you do this ?
