GoodLifeSpud
I'm currently trying to restore a 1980 Raleigh, 531 road frame, (pureists look away as I'm going for functional rather than authentic). I sourced a front derailleur from my LBS and with their help fitted it a couple of months ago.
Since then the project has stalled, but am slowly trying to get it over the final hurdles. One of which is wiring up the gears - I've never done this before, so this may be a stupid question. Can someone advise whether the cable should go on the inside of the black guide wheel (closest to the frame) or the outside as it is shown in the picture? Guide wheel is probably the wrong term but hey ho, live and learn.
I can't get back to my LBS for some time, due to work commitments, and have asked in a couple of shops near my work but couldn't get a straight answer. So any words of wisdom gratefully received; even if it's "it doesn't matter".
I've read a bit about routing cables and the general advice seems to be to avoid un-necessary bends; which would suggest the cable should be on the inside.
