Hello all,
You may have seen my previous threads about upgrading my MTB parts.
Well, all is now done, new parts fitted, rear Derailleur done, front Derailleur, well, needs help. According to Bicycle Tutor, you should leave around 2mm between the Derailleur cage and the largest chainring. However, if I do that, the opposite side crashes into the middle chainring when trying to change up. Here's a couple of pics to show what I mean.
Top picture - see how high I've had to mount the FD?
Above - even though the FD is mounted too high as per normal specs - the inside of the cage still only just makes it over the middle chainring.
I've compared the cage with the old one it replaced, and the "cage" is much larger than the original especially on the inner side, causing me to have to mount the whole thing higher up the pole than I normally would.
Any advice welcome!
Any advice welcome!
