Front light suggestions
RoadRider400
Some bloke that likes cycling alone
Please can I have suggestions for a new front light. Criteria as follows:
- My rides will be a mximum of 30 minutes
- Does not need to light up the whole world as I will mostly be on cycle paths
- Sub £35 preferably
- Not a Cateye product. My first was brilliant but the last two I had the battery life seemed to shorten quickly over the months.
For my 20min commute I run a Niterider Swift 500, I like its versatility with having an integrated bracket/strap.
https://road.cc/content/review/252199-niterider-swift-500-front-light
RoadRider400
RoadRider400
Cheap. Effective performance. Quality.
Choose any two.
That's what I used to think. However as previously alluded to each of my previous Cateyes were circa £60-£80 and lasted barely more than a year. I then somewhat reluctantly went for a random unkown to me brand from Amazon for £25. It was a brillaint bit of kit and lasted many years. Regrettably and foolishly I left it on the bike last night and it was pinched.
Sure there is a lot of cheap rubbish out there but there is also some great kit reasonably priced. You just need to know which ones...hence the post.
Widnes
I use cheap rechargeable ones - front and back
Alway at least 2 in case one runs out of charge on the ride - and because 2 lights are easier to notice than a single light
Personally I have a thried light that is brighter and more directional - I only use it in dark places to light up the path/track
Sharky
Kent
If you don't need a super bright light, consider ones with standard AA batteries. Easy to carry spares or to pop into a local shop/garage to get a replacement if one fails on your journey.
Re Cateye, I've never had a problem and extra brackets easy to source, enabling lights to be switched from bike to bike.
It's getting on for the time of year when you start needing those lights. It's comforting to have a light that has served you well and is reliable but it's as well to regard any light as disposable -even the most reliable light can suddenly die on you, never to shine again. Or, as in the OP's case become so much a part of your routine that you forget to take it off and get it nicked. It's always good to carry a spare out of sight. Aldi has bike stuff from Sunday, and their £9.99 lights get good reviews, cheap enough to use as a back up in any case. I've got a few cheapies for that purpose.
I've never spent a vast amount on lights. I've had a Lezyne 2W headlight used on and off for years, and despite the OP's experience with Cat Eye, have had a few over the years. They have reliable mounts that are common to many of their lights. I've had an AMPP400 for a few years too which seems a good compromise between battery life and output, and relatively commonly available and cheapish (also seem to be deals from time to time). If you ask for advice from this forum, everyone will have different ideas and experiences. I was resistant to rechargeable battery lights for a long time, but it's Hobsons's Choice nowadays.
oxoman
If its likely to get pinched then just get 2 amazon specials as a wear and spare. Over the years I've used a fair few different ones at different price points. I've got Moon xpower 300s, lezyne, niterider, moon lumina? , exposure joystick varying between 5 to 12yrs aold and all still used regularly on various bikes in winter. I've also got some cheap cree 3000 lumen ones for mtb that still work all be it with replacement battery packs. Good luck on digging your way way through everyone's advice.
N0bodyOfTheGoat
Hampshire, UK
Another option is look out for bike gear specials at Lidl and Aldi.
My Lidl set was ~£8 in March 2020, for a Strzo compliant front light and a shield shaped rear, plus I have some Moon (Meteor?) clones from Aldi from ~2015, both of which I still regularly use today.
Lidl did a bike gear thing at end of June, so it might be a while for their next one.
Widnes
The LED lights we have now mean that reasonably bright lights are dirt cheap
battery might not last long if it is rechargeable - but they last for several hours per charge in my experience
and they are pretty bright as far as visibility is concerned
si_c
Wirral
Halfords do a 500lm lamp for about £30 which is what I'd probably go for at that price - if it fails at least you have somewhere to take it. They also have the Cateye Amp 400 for £24 which I think is a good deal, but appreciating the preference against cateye.
The next one I'd probably look at (again also available at halfords) is the Moon Rigel 1000, looks as though it has good enough optics and the battery life is good for what you need it for. Beyond that I'd be spending £100+ on a front lamp to get the battery life and optics I'd want. For rechargeable lamps anyway.
You could also get a replaceable battery lamp but that usually comes with significant tradeoffs around needing a charger and spare batteries.
