wanj
Hi - today was the first time I took out my newish tourer for the commute to work. The difference between this and my usual ride is that I have a double chain ring at the front and a triple on my other bike. On the triple on the middle ring I get no chain rub at all, whichever rear sprocket I am on. With the double I can adjust the high and low so that I just miss the chain on all inner and all outer but it will rub at the other extreme - i.e. big front and big rear and small front and small rear. My question is - is this normal? Does it differ with different makes? Or is it just case of adjustment?
Cheers
J
Cheers
J
). With careful planning ahead in terms of cadence and so on, you still might not need to change the front rings much...
