FS Carrera Vanquish medium (56cm)
cyberknight
Bought this form a Bike radar member as a bargain, he had ridden it a few times and wanted a mtb , i have done less than 50 miles but it is just to big for me for comfort.
£300 ono new they are £550
Specs are
The Specs are
* Frame Material: 7005 Aluminium
* Gender: Mens
* Suspension: Rigid
* Frame Size (cm): 51 - 54
* Brake Type: Dual Pivot Caliper Brake
* Chainset: Truvativ Tour Compact
* Forks: Lightweight carbon fibre fork with alloy steerer
* Frame Colour: Black and Red
* Frame-: Lightweight double butted 7005 semi compact Aluminium
* Front Brake: Shimano Tiagra Lever, Tektro R720 dual pivot caliper
* Front Mech: Shimano Sora
* Gear Shifters: Shimano Tiagra 18 Speed
* Handle Bars: Kalloy Alloy Oversize 31.8mm drop
* Headset: Semi Integrated Ahead Set
* Hubs: Shimano WHR500 Wheelset
* Number of Gears: 18
* Pedals: Black resin with Toe Clips
* Rear Brake: Shimano Tiagra Lever, Tektro R720 dual pivot caliper
* Rear Mech: Shimano Sora
* Rear Shock: N/A
* Rims: Shimano WHR500 Wheelset
* Saddle: Carrera
* Seatpost: Kalloy Alloy 27.2mm
* Stem: Kalloy Alloy oversize 31.8mm
* Tyre size: 700 x 23C
* Tyres: Continental Ultra Sport
* Wheel size: 700c
cyberknight
cyberknight
Just a quickie noted that in the specs it says 54 cm , thats wrong i just pasted that but it will not let me edit ,
from halfords...Medium- bottom bracket to top tube which is equivalent to our standard 56cm frame
cyberknight
cyberknight
Yes it is misleading i am the same size and it caught me out ,virtual top tube is 56.
It was the reach that is too long for me as i have a short torso ,i could spend money trying to make it fit but i have decided to put the money towards one that fits from the start (i need a 52-54 )
cyberknight
cyberknight
cyberknight said:
Yes it is misleading i am the same size and it caught me out ,virtua EDIT SEAT TUBE 56.
mm whats happened to the edit post button?
cyberknight
cyberknight
Sold
Swapped for another bike :smile:
