Funny, and 100% true!
AlanW
Not to sure?
Let me set the scene, Virgin Media have decided that they are going to install a cable network to all the surrounding roads where I live. This obviously involves digging trench's along the footpaths and to say that it is causing mayhem would be an understatement!
Anyway....yesterday that trench finally reached the point where it had to cross the road. So they dug the trench half way across the road, and its usual that they then drop a large steel plate over the top to allow traffic to pass while they do the other half of the trench.
So as I drive into my cul de sac yesterday afternoon from work I am faced with a tipper truck parked on the left side of the road and a open trench on the right hand side with three workman telling me to stop and wait.
So I pull up and wait, the driver jumps out of the cab and trots down the side of the vehicle and drops the sides. Then the four of them join together and start to pull the large steel plate off the truck.
Its clearly a heavy piece of steel plate as they were really struggling to drag it across the bed of the truck.
Then for reasons best known to the idiot concerned, but one of the workman decided to crouch under the plate and lift it up and take the weight on his back while the others continued to drag it over.
Now you know that feeling when you can see something unfolding in front of your eyes and you ask yourself, surely not......it was certainly one of those moments!!
They continued to drag the plate and still with the clown taking the weight on his back. As soon as the plate left the bed of the truck his legs buckled and he immediately dropped face down in the trench with the plate on top of him!! The three remaining guys then frantically tried to pick the plate of him but couldn't as it was to heavy, so they had to lift up one side to let him out.
Apart from everything else, it was the speed in which he dropped down, and his "mates" letting it go!! It wasn't like he even held it up for even a split second. Added to the fact that his legs went in opposite directions as he disappeared into the trench just made the whole thing even more comical.....I just wished that I could have captured it all on film.
But by this point I was laughing so much I was hurting....
To be fair it probably doesn't seem that funny in words, but I had to try and share it never the less. And thankfully the guy walked away with what seemed like very little damage to himself.
Globalti
....and the video?
Saluki
World class procrastinator
I wish you could have filmed it too. You'd have got £200 from that video clips programme for a start.
I'd have loved to have sat and watched what you did. I can imagine the hilarity of seeing that first hand :rofl:
Globalti
Well if there's no video it can't have happened, obviously, because everything funny that happens nowadays is on video.
AlanW
AlanW
Not to sure?
The annoying thing is I had my phone sat on the passenger seat, but I was that engrossed in what was going to happen next that I didn't even give it a thought till afterwards.
cisamcgu
Merseyside-ish
Density of steel ~ 8000kg/m3
Steel plate - let us assume it is 6ft x 9ft x 1inch ~ 200cmx300cmx3cm = 0.18m3
0.18m3 = 0.18x8000 ~ 1.4 tonnes :ohmy:
No wonder he disappeared quickly :tongue:
Globalti
I once saw an African market porter carry away FIVE drums of 25 kilos net (29.2 gross) on a reinforced wheelbarrow but he was at his limit, I don't think even he would have managed a ton or more.
Drago
they sound like real pros. Let's jus hope it's someone else installing the actual cable!
AlanW
AlanW
Not to sure?
If I had to has at a guess, dimensionally I would say that it was slightly smaller than as it was only covering a trench probably 2' wide. And it certainly less than 1" thick, 1/2" to 3/4" maximum. That said you still wouldn't want to try and carry it!!!
AlanW
AlanW
Not to sure?
Well.....sadly not.
And if the first story wasn't bad enough, my daughter told me what she witnessed the following day, same gang, same tipper lorry.
The tipper has a load of tarmac on the back and is reversing up the road while a bloke is stood on the back chucking it in the trench with a shovel. They stop when they get to where a large quantity of tarmac has to go where they have installed a large cabinet. Apparently the guy stood on the back then shouts to the driver to lift the tipper bed. Can you guess where this is going.....?
Driver then engages the hydraulics and revs the engine to speed the lift of the tipper body up, presumably thinking that the guy that was in the back is no longer there.......nope!
Tarmac starts to slide out and so does the goon stood in the back trying to hold onto the side of the tipper body while shouting to the driver who of cause cannot hear him coz he is revving the engine.
The net result, tipper body completely emptied all its content, including the bloke!
captain nemo1701
Space cadet. Deck 42 Main Engineering.
Bristol
I have worked on roads and to cover up one of our boreholes, we had to use a plate like this. I collected it in a Hilux and it was lifted on by a forklift. I felt the suspension go way down when it was put into the truck. It took three of us to slide it out and then we dropped it onto the road with a resounding clang!. These things are soooo heavy, serious injury can occur. I'm with Virgin and if I witnessed this gang of clowns, I'd report the incident as a 'near miss' to their H&S people:ohmy:.
