Gatorskins
Philhh
My front tire -a gatorskind of indeterminate age-it came with the second hand bike-seems to be shedding fine rands of rubber from the walls not a lot but one or two every ride- the tire doesn't look warn out according to the "dots" but does it need changing or am I being a bit fussy.would appreciate advise
Tangoup51
Probably been riding/stored at too low pressures and has had too much exposure to the elements. Cracked sidewalls seldom a problem for my tires but if you're starting to actually shed rubber when you're riding it's probably time for replacement because who knows how well the rest of the rubber is gonna hold up?
http://www.chainreactioncycles.com/vittoria-zaffiro-pro-road-bike-tyre/rp-prod109595
^ Recommended fix.
Philhh
Philhh
Thanks -I keep my tires at 100p.s. i so I guess it's age-I'll, get anew set for the autumn
Loch side.
Inflation pressure has buggerall to do with it. There's a lot of latex in Continental tyre sidewalls and will will shred and crumble with time. The biggest culprit is ozone. If you store your bike near something like a photocopy machine (unlikely) or near some of the weird domestic appliances mentioned here https://www.arb.ca.gov/research/indoor/ozoneproductsfactsheet.pdf then the aging is accelerated.
Continental tyre sidewalls are the worst in the industry. If they don't shed rubber, they shed strings.
Ajax Bay
East Devon
This is reputed to be a normal issue with many types of Continental tyre (and I experienced this with serial pairs of GP 4 Seasons). I found that I wore the tyres out before the loss of a few threads on the sidewalls became of any concern.
Depending on your weight and width of tyre, 100psi may be too high (off topic). You can consult the attached seminal BQ article and the graph it contains.
  • TyreInflationPressures.pdf
