Not quite but close, am a cpl cm shorter but a cpl cm longer inside leg, ride a M in Giant bikes (have 2) one is a Defy Advanced.
often have to switch out the stock stem for a 100 or possibly a 90 but this would account for your extra body length so it could be a natural fit for you out of the box. Do you have a Giant store anywhere close to you?
Unfortunately none of the shops have anything in stock. Being in N. Ireland, it's even more limited with shops. Judging by other comments I've read i don't think a size small isn't going to be a good fit
Sorry, meant wouldn't be a good fit. Think medium is gonna be better suited like you saidsorry - is or isn't?
I would think an S will be too small but you maybe able to put a longer stem on. I would suggest an M would be better, based on my experience but we are all slightly different and things can often be adjusted or tweaked to fit, especially if close to the boundries of two size option, hard to tell without trying it for size really.
With what's available over here, a boat trip to Liverpool isn't a bad idea 👍Possibly a little extreme, but being in NI, there is a Giant store in Liverpool - a bit of a trek to try out a bike, but may be worth it if you really want the bike.
There’s not much more available here. If you’re going to do that, call first, have a chat, see what they have or can get in, put a (likely refundable) deposit downWith what's available over here, a boat trip to Liverpool isn't a bad idea 👍
Mine (Defy Composite 3) from 2014 is an M/L and I'm 178 cm, the bike is a tad large but not too big, the M would be the correct size, but it works well for me.You really have to try it, I have a M/L Defy Advanced and I'm 180 cm.
I was too bunched up on the M, I love the bike.
Good Luck.
The other thing is reports of cracked seat tubes were there is a lot of seat post showing, I’m happy that the seat post on mine has still got a fair bit in the seat tube, which wouldn’t be the case on a frame that’s too smallI wouldn’t risk a small. I am similar short leg upper torso to you and a medium was just right. Even with that tall head tube you would likely to be too low as well as cramped.
