Me too. If I realised I’ve missed a turning just a few hundred metres down a road, I refuse to go back and often carry on for another km or so to get back on course!
I'm still not back on track.
i create my routes in Strava and they appear on the Garmin like magic, no in between software required.
I don't do "training", just recreational cycling but when touring the ClimbPro feature is fantastic. Load next day's route and it scans for "climbs" and before even starting it will show you how many, where and how "bad" the climbs are. Once underway it will tell you how far to next climb so you can ease off so you don't arrive at the bottom of the hill exhausted. Plus know when only one climb to go, not far to top, all climbs for today done, ... etc. Brilliant touring feature.Climbpro is a revelation I would not be without.
On 1050 Garmin recently did a bug ridden release. My guess was probably one bug but in common of OS and was causing large numbers of devices to keep failing eg crashing every few miles. Garmin despite acknowledging the issues refused to allow anybody to revert to previous working version. Standard issue with Garmin - excellent hardware but very poor software. They need to sort out their software development, have needed to for some time.its had one problem in that (possibly my fault) it failed spectacularly during an update
Even worse is once the device detects an update you have to be very very careful, answer "now" or "later" and update can't be stopped; you have to close the pop-up without answering again and again and again ... forever. Trick I've done is blocked access to their update domain so it can't even check for updates nor download any so I can wait on a stable version and check after a few weeks how many are reporting what bugs before allowing any update.
Updating is a risk, particularly where historically Garmin have released very bug ridden versions. Hence control and delaying/preventing updates is crucial. I won't update any software mid-tour both because of the risk of introduced bugs but also because the rubbish campsite Wi-Fi or limited/expensive mobile data I may want to create tomorrows route, backup photos, etc. more important stuff than updating a working system.Last night for the first time as I shutdown my Garmin XT2 motorcycle satnav it started an update all on its own, i will be out on the motorbike again tomorrow so guess i will see how successful it was and has it has changed.
It was version 13.13 for the 1050 several months ago. Garmin reps were posting things likeTBH I've never had a problem with Garmin updates. I decline them when prompted unless I'm at home, with WiFi and a bit of time to spare. When I'm ready I restart the device and leave it to do its stuff. Older wired devices I periodically check using Garmin Express. (That's from over 20 years and maybe half a dozen different devices.)
Hello all, we understand there are many members of the community here who are seeing crashes/freezes/reboots during activities after installing the latest update.
First, I want to acknowledge the frustration you have as this is completely valid
etc., etc.The number of users who agreed to help provide feedback in our Sticky Thread requesting this has been a tremendous help, and we currently believe we have the cause identified and are working on a fix to provide to impacted users.
It's actually a strange balance. All software has bugs, just a question as to how many and how serious for any given use. On tour one year my long stable Garmin happily navigated me turn-by-turn every day until after a few weeks one day the turn by turn just stopped working, route fine and showed on screen fine, marker following the route fine but device just kept saying eg turn left in 999 miles. Recreated route, part route, etc. and all failed in same way. Next day's route and rest of tour (another 5 weeks) worked fine every day.I wasn't doubting you, @Psamanthe Just saying that I've never had any issues on any of my devices.
I'm in the process of replacing my Wahoo Elemnt Bolt and some on here seem to like the Garmin Explore 2. I sthat still relevant or oustripped by now?
It's reasonably priced at around £200 too.
My thoughts would depend on what you actually use your Wahoo Elemnt Bolt for. My Garmin GPS (Edge) does loads and loads of stuff I don't use But I spend excessive amounts on the models I get to get the one or two features important to me.I'm in the process of replacing my Wahoo Elemnt Bolt and some on here seem to like the Garmin Explore 2. I sthat still relevant or oustripped by now?
