Yes... the mudguard mounting on mine is very similar to this. The new seat frame has a slot on the seat itself for angle adjustment but if you want to have some adjustability with the ICE seat you’re using, the slot would make it easier.
I've been experimenting with the spare aluminium tube from the walking frame; I think I'll try using the slot (A) for the lower securing bolts for the seat stay.
As you don’t have a moveable jockey wheel to know where to fit the brake calliper you may have to play about with various positions until you get the callipers in the right position... though I’d guess that middle is the best guess!
Not sure what exactly was meant when the Manual referred to a "moveable jockey wheel" - do you think it was the additional mounting plate visible in their photo ? I have not experimented with the "plate" that's on the Left rear upright - I'm presuming it is only there to support the brake caliper ?
OT any chance of a picture of the other side of the trike? I’m curious about the relationship of motor to bottom bracket to frame. I might have some ideas for mods on my own trike...
OK, no problem. You'll know the Hase BB's have a 65mm width, then with the 3mm of the chain tube stay the total would be the standard 68mm. I admit I haven't yet made a chain tube stay for this Kett - I have the aluminium sheet, ready, but have been waiting until the drive train is working before I fettle that. I've put 2 lock rings on the TSDZ2, but will likely ony have room for one when the chain tube stay is put in place.
The black torque collar was a clamp left over from the handbike - with a longer M8 bolt it does the job nicely.
