Having some issues with changing gear... Not uncommon and usually a little adjustment or replacement of a "consumable" sorts it out, but this time I'm a little stumped.
In this order I have changed...
1 - Chain, just because it was due. Then my problems started.
2 - Rear Shift cable
3 - Cassette. I didn't think it would help as I'd only run two chains on it so far, but what the hell I thought. I can always put it back on next time. It made no difference.
4 - Jockey wheels. There was more play in them than I would expect. It's helped, but it's still not right.
I've spent masses of time trying to tune up the gears, but you get it right in one direction, and it doesn't work in the other. You get it working at the bottom end, it doesn't work at the top. Sometimes it's just completely inconsistent.
This list only leaves two remaining suspects: Dérailleur or shifter. Both are equally expensive and cost too much to just "give it a try", unlike the cassette which I'll get through eventually anyway.
My bike has done 15'000 London miles. Therefore it's probably done 8 or 9'000 gear changes. I've never run a pair of shifters into the ground before. Does anyone have any idea how long they should last? Could this be my issue, or does anyone have any experience that might show I'm barking up the wrong tree?
Thanks all in advance.
