Norm said:This is true. Whilst it was done in the days of film, print film can capture a much broader range than slide film, and slide film can capture a much broader range than sensors can at the moment. HDR originally became popular to fill the over- / under-exposed gaps in standard digital photos but, by pushing the process like that image in rich p's OP, it has become a stand-alone technique.
Norm said:No, that would be because things moved between images.![]()
. Buildings tend not to move.Tollers said:Used badly it looks crap. You still need to be a good photographer to do good HDR. It's just a tool to help achieve a different effect. In the wrong/untalented/tasteles hands you, you end up with ....
Davidc said:No, it's more basic!
The camera takes 3 pictures, in the right order (I think its darkest first) and the software then combines the images.
If theres something in one which isn't in the others you end up with a combination of the something and the absence of it. It's analogous to multiple exposure with conventional silver nitrate film, but for pictures of spooks it's even better because of the tricks the software does.
I took some interior pictures a while back where there were 3 TV monitors going occupying about 1/3 of the field of view, and fortunately checked the results before leaving. Weird doesn't describe it adequately.
Crankarm said:Nice Tollers. Your work?
Tollers said:Aherm.....no!
HDR isn't really my taste and as others have said it's been overused and is now almost a cliche.
Having said that, here is some HDR that I do like
OMFG, I am so +1 with that!Tollers said:HDR isn't really my taste and as others have said it's been overused and is now almost a cliche.
Indeed. That is where HDR works well. It would be difficult (impossible?) to have captured the sun coming through the clouds and, more particularly, the church interior with a single digital image.Tollers said:Having said that, here is some HDR that I do like
I have worked with both, and clouds still move.Crankarm said:I know never work with children or animals. Buildings tend not to move.
As you can see in Sam's lovely shot, there's some ghosting in the sky in places.Crankarm said:I do enjoy your posts Norm.
Thanks.How badly bumped? You might still be able to use software to overlay the images precisely if most of the shots still overlap.Sam Kennedy said:I had taken about 12 photos, but could only use 3 since I accidentally bumped the camera![]()
Sam Kennedy said:Okay it turns out there was only 1 picture which was blurring everything, so after removing it, and playing around with photoshop curves (they are tricky!) I got this:
It looks a lot more 'flat' than the other image. Where is is misty in the right of the image, is probably caused by a bright street lamp just out of view.
Crankarm said:I like it, as far as one can tell from a low res image on a forum.
