yes, it was very rough. I've found replacements through MB Bearings thanks.Does the top bearing actually need replacing? It is usually the lower bearing that takes all the hammering and is also the one that suffers from muck and water ingress. Top bearing is usually as new even when the bottom set are way past their best.
Yes I was expecting the bearing to have more of a tapered side to it. the top bearing does have a 45 degree on one side. They are integrated bearings, so no headset as such.6808 is a standard deep groove bearing. I find it strange that your headset has such a bearing, since they are very unsuitable to headset use. Most headsets have angular contact bearings (ACBs). What headset is it?
Strange, especially on the bottom.Yes I was expecting the bearing to have more of a tapered side to it. the top bearing does have a 45 degree on one side. They are integrated bearings, so no headset as such.
