EzaBlade
- Sheffield, UK
I have a problem of my own making but I'm hoping to find a way to solve it and any help would be appreciated.
On my Canyon Endurace I decided to service and degrease the headset bearings. I loosened the stem bolts and removed the top cap and spacers. Based on watching some you tube videos I was expecting the fork to be removable, some videos even said to hold the fork in case it actually fell out at this point.
(The fork is carbon)
However, in my case I could not shift it. I looked down into the top of the fork and could see the top of another Allen bolt so I decided to loosen this, assuming it to be the reason the fork would not come out. It appears that the top cap bolt goes through the head of this bolt and tightens into another thread.
This did nothing and I found that the tightness of the top bearing on the fork was preventing the fork from falling out so I carefully tapped this slowly off from the top so that the fork could be removed. All good I think! I proceed to clean and regrease the bearings that were ok (there's not a massive mileage on the bike).
The problem occurred when trying to put everything back. I carefully tapped the bearing back onto the top of the fork. I then tried to tighten the Allen bolt down inside the top of the fork, but it just went round and round without tightening. This wasn't looking good. I thought maybe if I continue and refit the stem and the top cap that it may tighten but of course it didn't. I now have a stem installed with a top cap that won't tighten and something inside the fork that must not be doing its job - and can't get the stem back off.
Any suggestions on what to do fix this would be much appreciated.
