Jacomus-rides-Gen
- Guildford / London
I've spent a pretty frustrating day working on an essay that is going nowhere, and on my way home for dinner I took a longer loop and pedalled away my frustration.
As I was nearing home I was pushing the envelope a little
and hot on the pace, I approached my favorite corner on my commute.
Its a shared path, a good 3m wide, decent surface but slightly rippled by tree roots, not enough to crack the tarmc, but just enough to be challenging on the corner. I take a tight corner to the left, thats slightly downhill, and is at an X shaped intersection. Anyway, its a cool corner to take at speed, especially since you can see along all 3 paths before you get there, so that you know if you can go fast or take care of peds and other cyclists in advance.
I saw with glee that it was totally clear and lined myself up, and leant into the corner at serious speed. I felt and heard the front wheel squirm on the edge of grip and almost as soon as I apexed the front wheel let go and slipped
Luckily I let the bike move underneath me, and the front gripped again, but I had come off my edge to edge line and was headed for the wet grass at 30kph on a roadbike
I didn't manage to correct my line and everything went a bit agricultural. In short order I was sliding along the grass still attached to the bike. We came to rest unharmed but very wet and muddy. As I got back onto the path I met an old gentleman riding a fairly heavily laden Spesh Tricross.
"Have a little trouble staying on the path eh?"
"Erm, yes. Too much legs, not enough brain"
"Indeed. I remember running wide on a corner as a young man, I hit the verge and landed in a drainage ditch full of water with a broken collarbone."
The convo continued, as we cycled together for a short way before going in seperate directions.
Just thought I'd share. Cycling rules!! If I had been silly like that in a car or on a motorbike (which I doubt I would have been, the place for speed is on track not on road) the result could have been very serious indeed. As was, I got very muddy, and had a pleasent conversation with another cyclist. I would have preferred not to crash, but I can't say it turned out too badly
and hot on the pace, I approached my favorite corner on my commute.Its a shared path, a good 3m wide, decent surface but slightly rippled by tree roots, not enough to crack the tarmc, but just enough to be challenging on the corner. I take a tight corner to the left, thats slightly downhill, and is at an X shaped intersection. Anyway, its a cool corner to take at speed, especially since you can see along all 3 paths before you get there, so that you know if you can go fast or take care of peds and other cyclists in advance.
