numbnuts
- Gone over the hill and far away
This is like saying "if all woman wore chastity belt there would be no more rapes"
Yorkshireman said:More information here :-
http://www.ctc.org.uk/DesktopDefault.aspx?TabID=5180
srw said:And one quick, but important observation - the title of this thread is wrong. It might be helpful to change it.
dodgy said:This is just about to be discussed on R2. I won't listen because it will be the usual irrational outpouring of hatred against cyclists
Let me know if I was wrong.
dodgy said:Thanks Matthew, I really am not listening because I'll be wound up all day thinking about the mouth breathers in our society. Keep us informed!
srw said:My second problem with that article is that it implies that someone is thinking that cyclists should be treated as a special case. If it can be proved that, on the balance of probabilities, wearing a particular sort of protective gear would have reduced the severity of a particular injury, then the law of contributory negligence should apply.
Cars could be made to the same safety standards as Formula 1 vehicles. Where does this logic end?
I'd argue the same for any sort of injury. If a car driver ripped out his car's airbags, and was involved in a collision in which a correctly installed airbag would have prevented injury then again contrib should apply.
Not the same at all. Not all cars have airbags anyway. Is that contributory negligence? Should they have to be retro-fitted?
asterix said:Not the same at all. Not all cars have airbags anyway. Is that contributory negligence? Should they have to be retro-fitted?
srw said:It's exactly parallel.
Car driver <--> Cyclist
Airbag <--> Helmet (neither is compulsory; neither is universally fitted)
Choice not to have an airbag <--> Choice not to wear a helmet
Proof that the absence of an airbag contributed to an injury <--> Proof that the absence of a helmet contributed to an injury
The judge was doing no more and no less than correctly applying the law, having been asked to make a specific ruling in a specific set of circumstances.
srw said:The judge was doing no more and no less than correctly applying the law, having been asked to make a specific ruling in a specific set of circumstances.
Chris James said:As regards this specific case and your point about 12mph, how can you state that helmets are effective above 12mph if they are not tested at that speed? There is no evidence either way.
