Ooops - should've read your other postOnce upon a time I'd have had a go. But my brain has shrunk too. How patient are you? If you are very patient I could attempt to solve your problem.
One way around this is to use square posts with corners lined up with the base. Then it's just a bunch of 45 degree cuts..........
Is a compound angle, the 2nd angle will alter the 1st.
Easy way, 3D cad., just need to find someone who has it.
Phew - I won't bother attempting it nowPuts hand up... 3d cad is my job... Give me the dimensions of what you have and ill knock a model and a drawing up, only take me 5 mins. . .
