Archie_tect
De Skieven Architek... aka Penfold + Horace
- Northumberland
@User9609, you're getting 30 degrees because you've used cos 45deg as 0.5 instead of 0.7071 so the louvre wouldn't be 56mm at Lv it would be 40mm, because both the post and the louvre are set at 45 degree splays they'll both be the same width . Then it should work through as 35 degrees on the splay junction?
[/QUOTE]
[/QUOTE]
