Maths / Electronics question...
Andy in Germany
I'm currently trying to practice the maths for parallel resistance, and the "worked examples" are frankly quite entertaining. Could someone with a more mathematical brain explain?
The equation given is:
1 / r (total) = 1 / r1 + 1 / r2 + 1/ r3
However my experience with maths is that I probably won't understand it: I just need to learn to use the equation and the number on the other end is usually the right one. However, this doesn't make sense to me because what use is knowing "1 / r (total)"?
The problem set for me was:
r1 = 9Ω
r2 = 9Ω
r3 = 9Ω
Find r (Total)
= 0,1111 + 0,1111 + 0,1111 = 0,3333 Ω
So 1/ r (total) / 1 is 0,3333 Ω
I wasn't sure what to do with this so I looked up the solution. It said:
r Total = 93 = 3Ω
This didn't help, so I asked AI an AI programme. This is what AI said:
For three resistors in parallel, use:
1/r total=1 / r1+1 / r2+1 / r3
Example:
R1=6 Ω,
R2=3 Ω,
R3=2 Ω
Substitute the values:
1 / r total=1/6 +1/3 +1/2
Okay, not sure how that should help, but I got:
1/r total = 0,1666 + 0,1333 + 0,5 = 0,7993Ω
But the "example" seems to go off the deep end:
Using a common denominator:
1 / r total =1/6+2/6+3/6= 1Ω
Where did the "common denominator" come from, and why is it a 6? To me it looks like it substitutes a stack of random numbers to get the right answer.
Can anyone explain how to consistently use the equation to get an accurate answer? I am aware this is a sign of discalculia; I don't understand how it works and probably won't, but I've found that given the formula, with care I can get the right answer, even if it is like pulling the lever on a fruit machine.
I just need to pass the exam, have the certificate, and can get on with my real job, so any assistance is welcome.
Ming the Merciless
There is no mercy
Photo Winner
Inside my skull
The first bit you did correctly
1/r = 1/9 + 1/9 + 1/9 = (1+1+1) / 9 = 3/9 = 1/3
But that is 1/r not r. To get r you have to take the reciprocal. Thus r = 1 / (1/3) = 3. The other way to adjust is to multiply both sides by r. Thus (1/r) * r = (1/3) * r. Cancelling terms you get 1 = 1/3 r. Multiply both sides by 3 and you get 3 = r.
T4tomo
the denominator is the bottom number of the fraction, to add fractions, if they all have the same bottom number you just add the top numbers.
so in your example all of 6, 3 and 2 are factors of 6.
if you multiply r1 r2 & r3 together you will find a common denominator, but not necessarily the lowest. in this example it then becomes 36.
hence you rewrite 1/6 +1/3 +1/2 as 6/36 + 12/36 +18/36 = 36/36 =1 so 1/r =1 and r=1
but if you'd use 6 as the LCD then it 1/6 + 2/6 + 3/6 which still = 1!
T4tomo
Example 2
if it was say 3. 4 & 7 ohms
1/3+1/4+1/7 - so need a number they are all factors of. 3*4*7=84, so
i.e 28/84 + 21/84 + 7/84 = 56/84 or 2/3 therefore r=3/2 or 1.5ohms.
Andy in Germany
Andy in Germany
How do I know what the reciprocal is?
Dogtrousers
Lefty tighty. Get it righty.
I think you're asking two separate questions here:
1) How do I calculate resistances in parallel? This is physics, but uses maths
2) What's all this about lowest common denominator? This is just maths,
Now, knowing (2) actually makes it easier to tackle (1) but you don't HAVE to use it. If you have access to a calculator you can use that.
your example of 6, 3 and 2 you could just use your calculator or, better still, a spreadsheet to add up 1/6, 1/3 and 1/2 which will give you 1/r you then take the reciprocal of the result (one divided by the result) to give you r.
So 1/6 is 0.1666, 1/3 is 0.1333, and 1/2 is 0.5. You need the sum of these fractions.
Add them together you get 1/r = 0.9999 - that's a rounding error because I've truncated the numbers above. Take it to be 1.
Now divide 1 by your sum of the fractions. 1 divided by 1 is 1 so your answer is 1.
Learning the maths of how to deal with fractions is useful, and it does make it easier and more elegant once you've learned it. But if you're having trouble with two things at once, just brute-force it with a calculator or a spreadsheet.
Knowing about lowest common denominators is only helpful when you have nice co-operative numbers. If your values were 3.2Ω, 8.46Ω and 1.03Ω then all the lowest common denominators in the world wouldn't help you.
So in short, my advice is: Rely on your calculator for this. Write everything down step by step.
Consider learning more about handling fractions as a separate exercise if that's what floats your boat.
Andy in Germany
Andy in Germany
Example 2
I can follow up until you added 28/84, then to mee it looks like we are back to random numbers. I can see where the 84 comes from but not the 28 or the 21, or the 7,
I understand how 56 is 1/3 of 84 (with help from a calculator) just not how we get 56 in the first place.
What I really need is a step by step instruction to follow. As said above, from experience I probably won't understand the equation, but if I have a set of steps to follow then I can be confident of getting the correct number at the end.
If that means "Add the top row and multiply the bottom, then divide the bottom by the total of numbers on top" or whatever that's what I'll do, then I'll practice until the exam, and forget it a day later.
Dogtrousers
One divided by the thing. Reciprocal of a half (0.5) is one divided by 0.5 = 2.
Smarty pants people with more maths would just say, well a half is 1/2 so the reciprocal turns it upside down giving 2/1. But if I were you I would just take my calculator and do one divided by the thing. Or maybe it has a reciprocal button
sungod
putting things into words rather than equations may help see what's going on
the rule for calculating the effective resistance of a number of resistors that are wired in parallel, is to take the reciprocal of each resistor's value, add up all the reciprocals, then take the reciprocal of that total, this gives you the effective resistance
as an aside, should you ever need it, the same rule is used to calculate the capacitance of a number of capacitors in series
