Help needed for finding a replacement rim!
kovacsa
Hi All, These are my current rims: Wheeltech TD26 by Alex Rims (can't find much info about these online). I need to replace the rear wheel as it is cracked (cracks on the rims around a few spokes)
It's a 700C disc brake rim with quick releases. What do I need to consider other than the size of the wheel when choosing a replacement? I'll likely migrate over the cassette and rotor (if need be). My knowledge of rims is limited so any help is appreciated!
Here is my bike: https://www.bikes.com/en/bikes/whistler/2015 (Must select Whistler 70 when on the site)
Thanks all!
raleighnut
Can you not get a new rim laced onto your old hub?
K
kovacsa
Hey, I just learned that that was an option! What do I have to look out for when finding a replacement rim?
Cycleops
Accra, Ghana
But don't you have Alex rims on your wheel?
Use the contact function to explain to them what you need and ask them to suggest a replacement from their current range.
Alternately source a wheel locally the same size and width of rim.
the snail
Chippenham
Alex rims are hard to find retail. If you replace with a different rim, then it needs to be the right diameter (700c etc) suitable width, right number of spoke holes, similar ERD if you want to reuse the spokes.
Cycleops
Accra, Ghana
That's right @the snail and we don't know where the OP is. Maybe not in the UK?
