Katherine
- Manchester
Hi and thanks in advance.
I have had 6 rides and done about 100 miles so far on my new Dawes Super Galaxy.
Today I wiped the chain and put some lube on.
I spun the wheel through all the gears. To change the gears, I lifted the back wheel, moved the lever and moved the pedal with my hand. I went through the rear cassette with the front on the middle ring. Then I changed the front rings with the rear cassette in about the middle.
I did the small ring last and afterwards I couldn't move it back up to the middle ring so I took it out to pedal it on the road. It took 2 clicks to move onto the middle ring and won't move up to the large ring as the lever is now in the position for the large ring while on the middle ring and moves into the middle position when on the small ring.
I rang my son (Husband is working) who says I should have had the bike upside down!
He told me to try moving the chain manually onto the small ring while the lever is in the correct position which I did but when I rode it and tried to change it onto the middle ring it still took 2 clicks and ended up with the lever in the position for the large ring. I then tried to manually move the chain onto the middle ring while the lever was in the middle position but as soon as I pedalled it went back to the small ring.
Now what?
Husband and son could look at it tomorrow or is this a job for the bike shop?
The bike has not had its 6 week service yet.
Now what?
