Over The Hill
- Ridden off into the sunset
I have two desktop comuters. One on vista, other on xp. And one all in one printer/scanner HP Colo(u)r laserjet 2820.
They both print out of usb ports and work when the printer is directly plugged into them.
All I want to do is run the same printer from both computers without having to move the wire accross the room each time!
I started with a Belkin Peripheral switch. This came with a disc and it set up a little button on the bottom of the screen to swich the swich to the computer.
It did not work and Belkin support says it will not work with an all in one printer.
So I moved down a grade to a simple push button manual switch this one is by Konig. It has no driver and no installation details so I guess it is just a simple switch. My thought is that if I am switched to the right computer, it should not even know the switch is there and should work as normal.
Problem I seem to have is that the computers do not now recognise the printer (when set up via the switch). I tried re installing the drivers with the switch in place but it would not let me do that.
All I get is a print error and a message that is does not recognise the printer.
It will not fix itself or recognise the switch.
Has anyone else had this sort of problem? Any ideas on how I can get over it?
