Help with diagnosis
Emanresu
I asked AI to show the 'real' me.
S-i-l has a Rayleigh ebike (not sure of the model) from Halfords on a salary sacrifice scheme. It's been a problem since the start and is always back to Halfords for fixing. This time it is an intermittent fault where she cycles for a while and the assistance cuts out. Battery is fine but it seems to point to a component failure - but which one. Anyone have a fault chart for these models?
classic33
Leg End Member
Widnes
Possibly sensor issue or an intermittent connection ; Presume that Halfords have the diagnostic kit for i(think a lot of Raleigh e-bikes use Bosch).
Some do some don;t - although my knowledge might be a bit out of date
but when I had a Raleigh they manufacturers were very good at dealing with it
Of course - having Halford as an intermediary migth cause problems
but if it has been back and forth several times - or more - then I would be returning it as not fit for purpose and demand a refund or replacement
my Raleigh has certainly lasted very well once Raleigh sorted out the initial problem
if in doubt - contact Raleigh as well as Halfords - but the retailer has the responsibility to fix it as the contract is with them
Emanresu
Emanresu
AFAIK the bike is 2-3 years old so it may be out of warranty. If there is manufacturer support I may try that if someone has contact details.
Widnes
If you have a paper trail of the times it has been back then you still have some leverage with Halfords
They may not easily replace it but it might be enough to make them take it seriously
based on my experience with them the number of properly experienced bike mechanics they have if limited
and in some cases they have to go to different shop in the area for serious stuff
So if you put some pressure on them they might decided they better ring Fred from down the road
or you could send a complaint to Head Office
Good Luck
classic33
Leg End Member
e-mail: hello@raleighbicycles.com
However, on going to their website, I got this.
Drago
The Urban Fringe
You have rights under CRA 2015 as far as 6 years. If youve receipts and know the dates its been in for rectification youve a fair case for some level of redress.
gbb
Peterborough
My Carerra ebike suffered (as did many other peoples) from instant cut outs, screen blank, no power.
It could be reset quite easily by restarting everything but could be annoyingly regular.
I figured in the end it was the battery connection prongs, rattling perhaps, poor design perhaps, but always as ii went over any bump.
Solved it by firmly taping the battery to its holder. Far far from ideal but...
Worth checking ?
mjr
So many have had that experience with them, it's where the "half-odds" nickname came from, suggesting that the odds of getting a proper bike mechanic are half-and-half.
