Help with N+1 ....
tom73
Yorkshire
Having been on a mid ride last week when the heaven's opened riding in heavy rain was no fun and once the weather turn's made me really think I need a winter bike. Mrs 73 knowing me all too well is now all onboard for me to get another bike so I am in the market for a good all around one.;)
So I'm looking for a winter bike that can be used for most thing's on road and light off road, cycle path's , possibly bit of touring. That's not too heavy and won't break the bank.
i've found some to start with
https://www.merlincycles.com/merlin-axe7-tiagra-gravel-bike-2017-104289.html (currently out of stock in my size)
https://www.mangobikes.com/shop/bikes/point-ar/point-ar-tiagra/
https://www.planetx.co.uk/c/q/bikes/road-bikes/london-road
https://www.planetx.co.uk/i/q/EBPXXLAA1/planet-x-xla-apex-1-bike
Thought's and advice most welcome and others to add to list ?
https://www.ribblecycles.co.uk/ribble-7005-winter/
Although it is more road than gravel, classic winter bike, rim brakes
The mango looks good, aesthetic and spec
Unless you want 1x11 as the Planet X (but BB5s are crap ime)
No bike will keep you dry in the rain though :whistle:
tom73
tom73
Yorkshire
No bike will keep you dry in the rain though :whistle:[/QUOTE]
Getting wet is not a problem found out over the years I soon dry off
Joffey
Big Dosser
Yorkshire
My winter bike is a B'Twin Triban 540 - space for racks and guards and good tree clearance (up to 28mm) - maybe have a look at them too.
Spiderweb
Not So Special One
North Yorkshire
The Dolan Preffisio may be a bit beyond your budget at £799?
https://www.dolan-bikes.com/road/ro...sio-aluminium-road-bike-shimano-105-5800.html
T4tomo
Look out for a used cx / gravel bike and get a spare set of wheels so you have one with 28mm road rubber and one with 32 / 35 mm gravel tyres and fit mudguards. You are then pretty much sorted for anything for not very much.
youngoldbloke
The Ribble 7005 and the Dolan Preffisso are great bikes, BUT the mudguard clearance is VERY limited. Anything over 23mm results in frequent and frustrating mud clearing from the inside of the guards (personal experience). Both are quite 'dated' frames in that respect, and I'd be looking for 28mm clearance at least.
tom73
tom73
Yorkshire
I was thinking along same like you say they are both good buy's
tom73
tom73
Yorkshire
Had a look round as merlin one out of stock they have a 2018 version of what looks the same bike for extra £200
They also have this https://www.merlincycles.com/merlin-malt-g-tiagra-gravel-bike-2019-114706.html @£649
which comes £100 cheeper than the mango the 2 bikes looks basically the same to me
I have found this on sale https://www.rutlandcycling.com/bikes/road-bikes/giant-tcx-slr-2-2017-cyclocross-bike-black_372169 @£824 worth the extra or still over priced one plus over the other's is Shimano BR-RS405 hydraulic discs.
NorthernDave
Never used Über Member
I ran a Boardman Road Comp as a winter bike until last year. The current model now has disc brakes which is a welcome upgrade on a winter bike.
I've now got a Giant Contend SL1 Disc as the winter bike and while that model might be above your budget I'd recommend one of the lower spec models in the range. Room for guards and up to 28 mm tyres and I genuinely cannot fault how it rides.
tom73
tom73
Yorkshire
Found a good priced Cannondale CAADX Tiagra
Looks a good bike for the money , what the sizing like ? Normally a 53 but can only find 54 is that much of a problem ?
Depends what bit has been measured for sizing. You need to compare the geometries. If the same measurement used, eg top tube, you could always make up the difference with a stem change as needed
Not sure where you get 53 from though? Geo here
https://www.cannondale.com/en/Europe/Bike/ProductDetail?Id=821c97ee-5dc8-413a-b39f-3713cdb4fae4
Go try it out, only you can really know what the sizing is like for you. That said historically cannondales have come up ‘big’.
What bottom bracket does it use?
