I was hoping someone might be able to give me some advice on a very annoying problem with my disc brakes.
I have Shimano BR-M445 hydraulics front and rear. A month or so ago I replaced the front pads and they worked fine for about a week. Then they started shrieking (a real ear-piercing squeal even when perfectly dry) but more worryingly they started losing power. Within a few days the front brake was more or less useless so I couldn't rely on it. During that time I checked the alignment, cleaned the pads and rotor with Muc-Off disc brake cleaner but it didn't seem to make any difference. So, on with a new set of pads, and exactly the same thing has happened. There is also a dark band appearing on the rotor where the pads connect, and it doesn't seem to disappear with cleaning. I'm using my other bike for the time being as I don't feel safe riding when there is obviously a problem with my brakes.
I bought the pads off Amazon, but they are (at least appear to be) genuine Shimano products and the seller had very high positive feedback. I have triple checked that they are the correct (resin) pads and the packaging clearly states they are compatible with the brake system I have.
Has anyone had a problem like this, or have any idea what might be causing it and how I go about solving it? I'd appreciate any help.
Thanks,
Ed
Thanks,
Ed
