Since the Lezyne item on the Brompton chose to do the honourable things and end its own life recently, I need a replacement.
Probably the most important requirement is the ability to comfortably reach the 110psi max of the B's tyres. The Brompton-branded Lezyne claims to do 160psi, in use I never found it able to reach anywhere near this. It's 12.4mm piston bore suggests that it would require around 130N / 13kg applied force to reach 160psi; which on paper doesn't seem unreasonable although evidently I couldn't achieve it in practice!
On top of that I think I'd like a direct-fit / right-angle head rather than a hose as this was a bit of a pig to use on the Brompton's little wheels. I'd like to avoid plastic as much as possible (at least in stupid applications like the screw-thread for the hose on the Lezyne) and won't entertain the idea of anything else from this brand after this crap experience.
Fitting the existing Brompton frame mount would be a bonus but I appreciate this is probably unrealistic so I'm happy to carry the pump in the bag..
Thanks
Thanks
