thomas
the tank engine
- Woking/Norwich
LOL at the dreamweaver is frontpage comments.
I use dreamweaver for my sites. I find it really handy, the code view is pretty damn good and easy to use, both for html and php. Better than notepad and frontpage.
Design view isn't too bad...I believe the newer versions make CSS layouts? The dreamweaver i've got is just tables which are okkayyy if you're not that bothered. There is a table mode which is fecking awful for poor code with dreamweaver, but if you want to set up some normal html tables then it produces them quite quickly.
I find it handy as you can do templates for sites (if you can't use a CMS) and I can easily manage them all and update them. The FTP is a bit weak but does the job.
I've been using notepad++ at work recently, which for a code only program is quite good.
gaz said:So anyone that uses only dreamweavers code view doesn't know how to code?
