mattybain
- Cockle Bay, Auckland
BigSteev said:Ah, suddenly everything is clear (or possibly coated with jam)
So the missing factor is the area they are measuring the light over? without that it's pretty meaningless!!
Windward said:I just fitted the dynamo powered Cyo IQ, and even though it's the one with the reflector (so 40 Lux instead of 60) it is absolutely awesome. The great part is that the LED faces backwards, and is shaped by a reflector which gives a brilliant throw right across the road in a trapezoidal shape like a car headlamp, and which lights the ground right below your wheel- I don't have anything to compare it to myself, but I have seen people with powerful normal LED headlights and their beam is much more centered on a small circular spot, good for helmet mounting but gives you a smaller spot if on the bars.
About the blinding drivers bit, the IQ also cuts off the top of the beam like low beams on cars which means it doesn't blind people despite being so strong, I'm thinking about helmet mounting a hope adventure 1 (the wee version of the vision 1!) if I go on wee cycle paths at night, because with the IQ you can't see low branches and signs so well... or bats!
I'd like to compare it to hopes and ayups in the flesh though, they were my other two choices before I went for this!
mattybain said:So the missing factor is the area they are measuring the light over? without that it's pretty meaningless!!
directly at the source)downfader said:Excellent post, that light sounds fantastic.
I currently use a cateye 5xx model (forget which). Very bright but needs to be angled down closer than the standard 10 feet distance you're supposed to aim for. Its frankly no good for seeing the road by, the spot is the size of my fist on the road and despite the quoted 1200 lumens it seems no where near as good as the more expensive models.
My mate at work went to Shirley Market here in Southampton last week and picked up a front light for £3.99. 5x LEDs, good side vis and good throw, quick release too. Quite impressed
semislickstick said:Your Cateye will be in Candlepower not lumens.
1200 lumens should be very very bright from the impression I'm getting.
Now we are getting into adding Marmite on to the jam on the toast territory :-D.
