Maz
The rear brake caliper on my Allez keeps the brake blocks pressed against the rim when the brake is released.
I think I need to give it a good clean out and re-grease (the return spring looks a bit rusty and gritted up too) -too much crud build-up with no mudguards on, probably.
How do I take off the caliper to clean it? The whole unit is bolted to the frame with what looks like a hex-bolt, and there's another hex-bolt on one side of the caliper itself.
Anyway, does anyone know how to take the caliper off? Is this an easy job?
Thanks
Thanks
