Bigtallfatbloke
I suspect I may need a slightly smaller one...but I dont know what size my exisiting one is...where are the measurements taken from/to?
Unless BFTB has canged it, the Galaxy does not come with an ahead stem set up, it's a traditional one. Is that right BTFB?
...mine is the one supplied with the bike, which is a 2007 model Dawes Galaxy. There is a black headset thing with the Dawes logo on it and several spacers...the stem is some kind of alloy and is level..it's not one that goes up at an angle or anything. Bigtallfatbloke said:..erm...I dunno what the difference is...mine is the one supplied with the bike, which is a 2007 model Dawes Galaxy. There is a black headset thing with the Dawes logo on it and several spacers...the stem is some kind of alloy and is level..it's not one that goes up at an angle or anything.
I will measure it as per your kind comments and see if I can find one of the same kind but shorter.
Noodley said:BTFB, it appears this is may be an on-going saga which I have not been party to, but can I ask why you think you need a shorter stem?
Have you tried flipping the stem over? If it sits flat at present then flipping it over should give you a slight angle upwards which may solve the problem without any additional cost
