deano69
- kent ( Garden of England )
I would like help please on a good guide on how to size the chain lenth I need ?
I have checked out many online guides but still unsure as the one where you work out your largest front rings teeth eg 42 then largest cassette ring eg 32 then add chain stay length which is 43cm from crank centre to rear wheel axel centre then press calculate which gives me 137.16cm or 54 links....I tried this but when chain on largest front ring and largest rear sprocket derailleur cage is pointing forward under full stretch and strain but works perfect on other 2 front rings ?
I think 1 more link added will be ok but when its on smallest front ring and smallest rear the derailleur is filipped right back almost on itself .......getting frustrated now
