gbb
- Peterborough
I had a 2003 Focus for a while. Yes, the nearside bulbs were a bit fiddly to change because of the proximity of the battery, but not beyond the ability of any reasonably competent mechanic to do in situ, no need to remove the headlamp.
If you think cars are hard to work on, try aircraft.![]()
Im guessing i 'remembered' the wrong car..i did say 'Ford Focus..i think'...ive done a few over the years, 9 times out of 10 for someone else.I can't remember them being that bad? However a MK2 Focus is the easiest thing going. 1 screw, tap the unit out with your hand, cover off and replace. Swap a bulb in about 2-3 minutes
