How many Lumen for a good off road light ?
BADGER.BRAD
Shropshire
Hello all,
How many Lumen do I need as a minimum for a good off road night time light ? I have a number of off/on Road routes around my village in order to keep my fitness up but these will have to be done in darkness when the winter comes !
Many thanks for your replies
cyberknight
currently running 2 magicshine 1200 for commuting on unlit country lanes , i can run them at 600 lumens each so i get longer run times but gives me enough light to see where im going .
https://www.amazon.co.uk/Magicshine...Waterproof-Headlight/dp/B09PHDT7DM?th=1&psc=1
Definitely have a look at some of the newer lights with a cut off. I've a couple of Newboller lights that have been reliable (commuting) and their max is 1000 lumen, enough for unlit roads without blinding drivers, and have a distinct cut off, so ideal for road and shared paths. Magicshine do them also, and I have two of the Hori 1300. Has a cut off lens and a spot, and is remote controlled. So road, it's the cut off beam, then down unlit paths I can quickly pop on the full beam. You don't need more than 1200-1300 lumen maximum on a track/bridleway you know and road 600 is more than enough.
You need the big lumens doing proper off road on a MTB.
Drago
The Urban Fringe
There are lumens, lumens, and damn lumens. More reputable manufacturers will quote a more technically accurate figure taking into account the reflector and the lens. Others will just bullpois an impressive figure based upon the LED alone.
Thus the numbers cant universally be trusted, and are not even all that useful as a yardstick against one another.
Read the reviews and seek the experiences of users rather than rely on lumens figures.
Some of the so called 'cheap' stuff is good these days. Definitely look for cut-off lights. TBH Magicshine are really good these days, real quality lights - they are a Chinese company that started with the retina burning lights, but have developed some good stuff. I have their front and rear lights for commuting and day riding, some really good features. Their tech sheets tell you the output in various modes, and most of them are well within other road user 'comfort'.
Eg the rear Seemee 200 and 300 I have, only 'blink' the full lumen in day mode when it's bright (they have daylight sensors). In the evening, they default back to a 30-50 lumen mode, and only use full brightness in 'braking'. Some clever stuff going on. The Hori 1300 only outputs 1300 with the main beam on full for off road - the dipped is half that on maximum.
BADGER.BRAD
BADGER.BRAD
Shropshire
Thank you all for the replies ,the Magicshine range look a reasonable price and seem well liked so I will probably go for a set of them !
ktmbiker58
2300 lumens from my Exposure Toro 16 on mid setting which was fine for most of the trail but just enough for the downhills where I would normally switch to full power
oxoman
For pitchblack conditions on offroad trails I tend to have 2 cheap chinese 2000 lumen lights on the bars and a 1200 lumen exposure joystick on my helmet as my main light. The handlebar lights turn as you turn but not necessarily where you need the light, hence the joystick on my helmet that lights wherever im looking. For the road I have a moon xpower 300, plus niterider 750 along with 2 rear lights on my comutte bike. Don't always use the niterider unless wet or really dark. Having 2 front and rear gives me backup in case of failure or going flat as I stagger charging.
ktmbiker58
300 lumens on a halogen bulb was more than good enough for night time technical off road when I did a lot in my 30s and 40s.
Its amazing what we used to get away with - for most of my teenage years my road bike had the standard Miller dynamo lighting set with a 6V 40mA bulb in the front light that produced at best about 2 lumens, the light didn't so much beam out of it but fell out in a tiny yellow puddle barely in front of the front wheel. It was a huge improvement when I bought one of those Lucas front lights that had a 3V battery - much better light output but a bit like Russian Roulette you could never tell when it was going to go flat!
