I can't find my nuts
I'm trying to source some nuts for a Novatec front track hub axle.
These are ones that go up against the cartridge bearing - not to hold the wheel in the fork.
9mm axle, 1mm pitch (I think), ~4mm thick, takes a 17mm spanner.
Can't find anything remotely similar.
Any ideas?
ebay, but check on the pitch
rogerzilla
Most Japanese or other Far Eastern front wheel cone locknuts will do the job. Just check the thickness is close enough. Be wary of very cheap stuff, which may be 5/16", or Campagnolo which may be 26tpi (half metric, half imperial!).
