summerdays
Cycling in the sun
- Bristol
Is it well used at those sort of times? If it isn't then I'd stick to the roads or do a combination of the two.
The mornings can be busy with dog walkers but I cannot really see having a massive problem with them (as long as they move out of my way).Is it well used at those sort of times? If it isn't then I'd stick to the roads or do a combination of the two.
I know, after a few drinks I went out once and loved just weaving through the lines on the road when there were no cars to be seen at all.If you have a decent set of lights (and spares) cycling in the dark is great fun.
I also talk to myself quite a lot (had an embarrasing moment yesterday when on a river pathway) so I will keep myself from getting lonely.
Be courteous, perhaps ting your bell, smile and say thanks and most dog owners will let you pass, but don't assume and be prepared to slow down or stopI was joking by what I said, thats why the comment was in brackets.You are of course aware that the pedestrians have right of way, so you'll have to move out of their way, slow down or give way, not the other way roundBe courteous, perhaps ting your bell, smile and say thanks and most dog owners will let you pass, but don't assume and be prepared to slow down or stop
I know you don't drive but you really should read the Highway Code as well as Cyclecraft, reckon you could avoid a ton of bother.
Only the bits relating to cyclists.You carry a copy of the high way code ???????
