BentMikey
Rider of Seolferwulf
- South London
I'm a little sceptical, Jonny.
To the OP, what about an electric assist bike?
If you have the budget this could be a good solution (be prepared to spend in excess of £2k thou) anything under that (like the trek rear disk drive) will have a limited range.
I took a few Kalkoffs out at the beginning of the summer (allegedly the Rolls Royce of elec assist bikes)...in my quest for a bike that would allow commuting every day...and I found all of them frustrating in the same way. As soon as you hit 15mph the motor cuts out (by law) and you are then pedalling under your own steam. So as you hit 15mph you suddenly feel like the bike becomes very heavy and slow. It seems to stop you going any faster.
You can overcome this by replacing the rings/cassette (which is illegal but done for free by most bike suppliers??!)
Problem then is the ride is super fast (over 20mph) but your range drops by over well 50%. There is also a lot to consider with elec assist bikes, like the placement of the power pack, the method of drive (frictionless hub's etc) and the way in which the system free-wheels when not powered by the elec motor, life expectancy of the battery, and elec motor, charge times, gearing etc. Its easy to spend £2k on the wrong bike
In summary, if you wish to ride over 15mph (I like to cruise at 20) then elec assist may not help you
with life in general?
Yes, jump the lights.
A simple but probably quite daft question I'm afraid - I need to become faster. Any tips?
Sellotape a bundle of fireworks to your saddle?![]()
(I'll get me coat).
+1 on that.
I was totally set on buying a roadie this summer...did all the research took tests and picked the perfect one.
I managed to borrow one for a long ride and was totally underwhelmed. It was still just as hard/easy to ride and my average speed, acceleration and general movement didn't alter that much. the only real benefit I gained was an increase in my downhill speed ...but I only have one big hill on my commute.
I except that my expectations were probably too high and I'd led myself to believe that I'd float to work and I also understand that the gearing that I chose may be a massive factor...but still, what a disappointment, I'd have been livid if I'd replaced Chitty and spent a chunk of cash in the process.
Looks like Chitty's beaten off the competition once more.
